200 4R 'BRF' in a 1987 G/N
I have the tranny still in the car,if you live local come and drive it.
My reason for selling it is because about 1 month ago i took my car to a tranny shop just to have it serviced,they replaced the filter/fluid for $193.00
Everything was ok and then 4 days later i went to pass a car when i was driving about 45mph,then the tranny kicked down to second gear and just flashed NO More tranny
I remove the tranny and found that the stator support was stripped.
So i relaced the pump/hardened stator support,and replced the converter and filter/fluids
Now the car slips into 2nd and the same with 3rd,but it goes into 4th normally.
Under wot the car hangs up 1st to second and i have no idea about going into 3rd because i take my foot out of it.
I have decided to just replace the tranny.
Im located about 30 minutes north east of Orlando
I still have the original Converter and pump,i never swapped over the springs when i put in the new pump <maybe i should have>
$500.00 local pick up preferred
thanks for your interest,im tied up at the moment and will be for the rest of the evening.
is it ok to call you in the morning?
