Firechicken
- Jul 23, 2003
Originally posted by 77 cruiser
The no. of teeth only affect the speedo.
The colors might not tell the whole story.
Exactly. There are two sets of teeth on the governor gear. The small diameter gear meshes with the outputshaft and is the exact same on all the gears regardless of part number. The large diameter part of the gear is the only part that varies from one part # to the next. The large diameter part of the gear meshes with the gear at the end of the speedo, and when people refer to the number of drive teeth, this is the part of the gear to which they are referring.
The number of drive teeth (big part of gov gear) in relation to the driven teeth (speedo gear) , along with rear tire diameter, must be correct to ensure an accurate reading on your speedometer.
If you go to TCI's site HERE , you can determine what speedo gear you require to work with your current 13 tooth (Part# 8634934) drive gear and your current tire to ensure your speedo is accurate. At the same page at TCI they have a convienient calculator to determine your tire diameter too, as long as you know the size.
