Mike T
- May 3, 2013
I need to pull the valve body on my 2004r to free up a stuck throttle valve. I have read up a little and found that there are check balls above the separator plate (transmission case side). I would think that the check balls in the valve body will stay in place so that I will know where they go. My concern is that when the separator plate comes off the check balls above it will fall out and I will not know where they came from. Can the valve body be removed and still leave the separator plate attached to the transmission case?
Thanks Mike
Thanks Mike
