2004R street/strip trans with brake
brian
Senior Member
This Monte SS CZ (model) trans has all my usual parts. 550 and 400 boost valves, pump ring kit, Alto clutches (extra throughout) and wide Red band with our shift calibration.(shift kit)
This unit is a lock up with a big servo, and transbrake. The input shaft and drum are hardened. This trans will have nice firm shifts, and shift at nearly 5500 at WOT. Perfect for a ported heads and cam car.
Biggest difference between this and the BRF is a later WOT upshift, 5200 vs 5500, and a slightly earlier third gear while cruising. (most people never notice) With correct wiring for a GN, with the correct black plug.
This transmission is built to run into the 10`s with the right converter.
Price on this unit is $1450 + $150 shipping in the U.S. (continental 48) This price includes the core charge.
This transmission is built to be run with a 10 inch or similar hi-po converter. (9/11, Vig, etc)
You can also search the trans forum for info on the CZ valvebodies.
You can view feedback in that forum on this board.
Serach under brian, or Brian Hofer
Thank you, Brian
hipsibri@cs.com
Special for this week only. June 19-23.
$1500 shipped.
Thanks, Brian
