2004R trans Stage 1 rebuild to 500hp
youngerss
Do not PM me here....if interested email me at youngerss35@gmail.com
2004R o/d trans rebuilt by Lonnie Diers of Extreme Automatics back in July '10.......this is a Stage 1 rebuild to 500hp. Have receipt. See info below.
extremeautomatics.com
All Extreme Automatics 2004Rs
The build starts with only select cores
Case is media blasted and race prepped
All bushing are replaced
All Torrington bearings are replaced
All thrust washers are replaced
All seals and gaskets are replaced
Harden stator installed in every unit
Carbon Band installed in every unit
Billet anchor pin installed in every unit
New Pump assembly installed in every unit
EA Hi Pressure regulator valve and spring
EA Hi RPM pump priming spring
Billet pump rings
Pump drains drilled
Pump bushing staked
Tensioned Teflon sealing rings are used
3 clutch OD
Tested and sealed center support
Race clearances
Re-Calibrated Valve Body for firm shifts
Stage 1 2004R Stock to 10.90 ET 500HP
All Items Listed Above Including
Harden Forward Drum Shaft
Billet Servo
HO Low Roller Clutch
New OD Roller Clutch
Hi Performance Calibrated Valve Body **BRC
7 clutch direct Multi Parallel
Lock up or Non Lock-up
Governor Calibrated for approx 5000 RPM shifts
10 Vane pump Rotor and Slide assembly
1 Year Warranty ( 90 days on Forward Clutch Drum)
I paid $1,250 in 2010. Sell for $1000
Trans was built and track tested by Lonnie in a GN. I originally planned to install this trans in a '56 Chevy project but it never happened.
My loss your gain. Trans was only used for the track test and some around town driving.
Also comes with a custom built stock stall speed non lock up Continental Torque Converter if needed. Zero miles on it .........cost $700 new sell for an extra $500
Pick up near Crystal Lake Illinois
email replied
Hi Jim,
Just confirming our conversations of this afternoon thru this evening. I will take the transmission.....consider it SOLD.
Pls let me know your PayPal info so I can forward payment.
thanks,
dave
sold pending pickup!
Thanks Jim!
It was a pleasure meeting you and your son.
Got back home safely to Mississauga Saturday late morning with the transmission. Your directions to bybass downtown Chicago during Friday afternoon / evenings rush hour worked out great.
Made it as far as Flint, Michigan and had to call it a night.
Best Wishes to you and the Family for a "Merry Christmas" and a Happy, Healthy New Year!.
dave
