CZ MonteSS valvebody trans, ready to ship and fully tested. You can do a search in the trans area on CZ v-b`s. They are a very nice set up in a GN with ported heads and a cam upgrade. This trans will upshift at WOT right around 5500.
This unit also has all the correct wiring for a GN.
Billet drum, heat treated input shaft, rollerized gear train, 112 servo, and trans brake. This is a lock up trans and has a Hughes deep cast aluminum pan.
The unit also has 550 and 400 boost valves, 10 vane pump, rev kit, Alto wide red band, billet anchor pin, and extra clutches throughout. This is a fully capable mid 10 second trans.
$2000 with core included + $150 shipping.
Input shaft can be upgraded to billet for additional cost.
Feedback can be viewed in the feedback area. Search under, brian or Brian Hofer.
Thank you very much...
Brian hipsibri@cs.com
