I have a stage 2 2004R for sale. This unit is built and ready for immediate shipment. There is no core charge on this unit. I can deliver to BPG to save shipping. Other details can be found Extreme Automatics Where winning is easy under 2004R stage 2 Please call the shop if interested 937-379-2233
The build starts with only select cores
Case is media blasted and race preped
All bushing are replaced
All Torrington bearings are replaced
All thrust washers are replaced
All seals and gaskets are replaced
Harden stator installed in every unit
Alto super Band installed in every unit
Billet anchor pin installed in every unit
New Pump assembly installed in every unit
EA Hi Pressure regulator valve and spring
EA Hi RPM pump priming spring
Billet pump rings
Pump drains drilled
Pump bushing staked
Tensioned Teflon sealing rings are used
3 clutch OD
Billet Aluminum Direct Apply Ring
Tested and sealed center support
Race clearances
Re-CaBillet Forward Drum
Treated Input Shaft
EA Billet 2nd Gear Servo
8 Clutch Direct
5 Clutch Forward
Metallic Hi Energy Clutches
Dual Feed 3rd Clutch Apply
Hi Performance Calibrated Valve Body
.400 Reverse Boost Valve
No Core Charge
1 Year Warranty
$1850+ shipping
Billet pump rings
Pump drains drilled
Pump bushing staked
3 clutch OD
Race clearances
Treated Input Shaft
8 Clutch Direct
5 Clutch Forward
No Core Charge
1 Year Warranty
$1850+ shipping
