Aug 30, 2008 #1 J jimski In over my head Joined Apr 26, 2008 Messages 1,019 87 grand nash trans gets weak 1-2 shift at higher rpm.Transgo kit installed inside,any thoughts
Aug 31, 2008 #3 J jimski In over my head Joined Apr 26, 2008 Messages 1,019 So putting transgo pump rings and high rev spring will corect this?
Aug 31, 2008 #4 7 77 cruiser Well-Known Member Joined May 24, 2001 Messages 1,359 jimski said: So putting transgo pump rings and high rev spring will corect this? Click to expand... It's possible. Could you test the pressure & see if it's dropping @ higher rpm?
Aug 31, 2008 #5 J jimski In over my head Joined Apr 26, 2008 Messages 1,019 77 cruiser said: It's possible. Could you test the pressure & see if it's dropping @ higher rpm? Click to expand... I dont have a pressure gauge right now,but can u tel me the factors involed if pressure is lower or higher at high rpm thanks
