200R4 to TH400 Conversion
  • Thread starter Thread starter MSA231V6
  • Start date Start date
M
MSA231V6
Guest
Hi All,
I suppose this question has been tossed around a bunch before, but I did not see any threads that seemed to have the answers I am looking for. So..., here goes.
Can someone please highilght the basics as to what is involved when switching from a 200R4 to a TH400? I am planning this conversion in the near future and would like to find out as many details as possible before I start. Basic questions include:
-- Price for most 400's - either cores or new units from Buick vendors
-- Suggested converters - car should be mid to low 10s, near 125-130 MPH. My current converter in use with the 200R4 is a non-lock Art Carr 9"
-- Driveshaft recommendations
-- Any major mods needed to the crossmember, etc?
Also, one more question while I am at it... I will be selling my 200R4 to help finance this operation. What is a reasonable price? It is rebuilt with all of the heavy-duty parts - never raced since the last "freshing up." I will either sell it by itself or with the converter if it cannot be reused.
Thanks for the time and your advice.
Michael
Ok, here it goes. I cant' really give an exact price on a 400 but I'm sure you can get a good core anywhere pretty cheap. You do have to modify the stock crossmember and mount a little bit but I think that somone sells a mount for a 400 conversion. As for the driveshaft, my dad cut his a little bit, but I dont think its necessary. An Art Carr converter will work great as will a Precision Industries converter. We have a PI converter here if your interested in going that route. Hope this helps.
Will the Art Carr converter fit on the 400 as is? In other words, the spline sizes are the same, etc.? I may stay with what I have if that is the case.
Also, any chance you can list the gear ratios for the 400 (1 to 3) and the 200R4 (1 to 4)? I would appreciate it very much.
Thanks for your help.
Michael
Mike,
The Ac convertor will not work, totally different, the mountis all that has to be modified.
I would make a new driveshaft using a 1350 yoke in the front and rear, and use a 3" tube. You will probably find it is about 1/2" shorter. Buy a new shifter and that should do it. Total job including everything will probably run about $2k give or take alittle. That is figured on using the BEST convertor
ill
Here, use this to compare
We sell them all out, core and all for 1500.00
that includes a full roller unit, big bearing& big bushing to support case, blue plate high and second gear, 4 clutch int, 34 element sprag, red devil forwards, Hipster T-Brake, teflon servon ringed, and aluminum pan, Tested in a car and driven, all outright. I also stock sheilds.
So use that to compare.:)
Hi Bruce,
What convertor do you recommend for a car using a 400 with 28.5 inch tires. Running close to 130 in the 1/4 hopefully.
If you need more info let me know.
Thanks!
Michael
Depends on intended usage. And yes, alot more info would be needed.
Usage would be almost entirely race. Tell me what else you need to know and I will try to accomodate.
I appreciate your help.
Michael
