t-topflyer
- Aug 8, 2007
TH200-4R TCC Solenoid Transmission Problem
Using tips from the article at the link above, I've been trying to narrow down a problem with 4th gear in my 200 R4 transmission. I've had TCC problems with another turbo buick in the past which I replaced the TCC solenoid and the problem resolved. This is a slightly different problem and I need some advice before I continue to go about fixing it.
This problem is in 4th gear. The TCC engagement/disengagement seems to have a mind of it's own, and does so sporadcally around 55-60 mph and above. I just replaced the TCC solenoid, and while it does seem to stay engaged longer, it still doesn't seem to function exactly like it should. The car has an aftermarket transmission cooler and runs constantly between 160-170 degrees, so I don't know if the operating temp has anything to do with it. After replacing the solenoid, I don't know what system or systems I should look at next. The ECM, 4th gear pressure switch or ?? The internals in the transmission looked great. Any tips would be great. thanks
