206/206 maybe 204/214
qwikv6
I am looking at these 2 cams. I would like to have a part number and grind number on the "weber" 206/206. I called Comp Cams and was told that the part number for this custom grind cam is
Part# 69-000-5
Grind # BV69 5440/252-4 H110+4
Can anyone who has purchased the "Weber" 206 provide me with a copy of a cam card (preferred) or verify this info.
A buddy of mine ordered a 206/206 from a vendor and got the 206 listed in Comp's catalog. (part#69-234-4). Apparently this MAY NOT have been the Weber grind. It has been stated on this board that the lift on the Weber grind is .447. The lift on the cam that my buddy got was .425. What gives?
HELP!
I can get a 204/214 from work for cheap. I searched the archives for this info and have come up empty.
Any help you guys can give me is GREATLY appreciated...Thanks.
QUOTE: I can get a 204/214 from work for cheap.
_________________________________________
Sounds like a good idea!
The Weber is a .447 i have the paper work in front of me. Thats the cam that i have. Price for that is $165
Part# 69-000-5
Purchased my Weber Hyd roller 6/20/01 per the yellow cam card data is as follows:
Part# 67-000-9
Grind # BV6/3311/3311 HR109
Serial # T 0349
Gross vale lift .496 / .496
Lobe Lift .3200/.3200
Lobe seperation 109
Anything else??
Good Luck
PS It's a great cam:)
Re: Re: 206/206 maybe 204/214
Part# 67-000-9
Serial # T 0349
Lobe seperation 109
Anything else??
Good Luck
Damn..... My Ruggles 206 roller must be the biggest lift out there: .532/.532
Hope it works okay!:)
second that
screw comp cams
CPAKCP,
Thanks for the info.
I really wanted to get the info on the flat tappet hydraulic 206/206.
I should have specified that this is what I needed.
Anyone have this info?
