214-214 ROLLER CAM
guinea6
Here's a almost new (less than 100 miles) Revolution RX-5 ductile 214-214 roller cam ,from Full Throttle Speed (Mike) Absolutely nothing wrong with this cam it is as new.. Paid $290 plus shipping, will take $200 shipped
I just bought and decided not to use going a different route -- I copied and pasted the guys original post I bought it from -- still in the box he sent it to me in and never opened text or call 773 491 8806 or message is fine --thanks
This is a high intensity camshaft with very fast ramps and higher lift. It is for the guys who want to make the max power but still keep the RPM’s within reason. It is offered with fully ported heads, big turbos and high stall non-lock converters in mind. We used to run this cam in our old TSS setup with great success. It requires a stronger valve spring (PAC1219) that we will offer in the kit when this cam is selected. Roller rockers and at least iron heads are required-- 1.55 ratio is best for most applications; 1.65 ratio is not recommended.
Technical Information:
Intake Duration 214 @ .50
Exhaust Duration 214 @ .50
.547 lift with 1.55 rockers
.565 lift with 1.60 rockers
.583 lift with 1.65 rockers
