218/212 vs. 212/212
L8TRH8R
Can anyone give me there opinion on the difference between these two cams??? My motor is out and again and I'm thinking about going to a 218/212. Any thoughts are appreciated.
What are your goals? What mph are you trying to achieve. What converter? The 212/212 will take you to 135mph with 28" tires and 3.42 gears easily if the converter is up to par. You can easily max a set of stock diameter springs with a 212. Its hard to get enough spring on iron heads without extensive work.
I would like to get just into the 9's. The converter is a TCI race converter I believe its a 3200 stall with a super street fighter TH400 ... I have to pull out the paperwork to be 100% on the stall speed. :redface: BISON right after I bought the Razor kit from you i lost a head gasket and had MAJOR issues along with it so I have yet to try out the kit!
any thoughts ideas/parts needed or recomended are greatly appreciated!!!!!! I'd like to get it RIGHT this time... :frown:
212/212 is better for a street car that does see the track....
218/212 is better for a track ride...:)
Read the thread i started on the stock bottom end engine. Plenty of info about running a stock block engine hard that sees 99% street use. No need for more than a 212 cam if you have a converter that is spec'd properly. Its not easy to get enough spring on the stock heads to be able to run the rpm/boost required to take advantage of cams bigger than the 212. You need to get it done under 6000rpm.
Thanks Bison. I'm going to go with a 212/212 again as well as sell me th400 get a FAST XFI pts trans and converter as well as a steel crank... may just get some heads as well. We'll see how far the boss (wife) will let me go before she has her yearly Buick melt down!!!!!! :eek: If there is anything else you would recommend please do! Tahnks again. You have been a very helpful mind during this straight up hill learning curve.
