forcefed3.8's
Buckeye Bullet
- May 26, 2002
Siemens/Deka 225lbs injectors, used for 300 miles. These are the best E85 injectors i have ever used. Will support low 8 sec power. These are over $300 a piece new and are hard to find now. $1400 for the set of 6 plus shipping
70mm Accufab throttlebody. Come with IAC,TPS, throttle linkage arm, BOP Engineering angle iac boss, has 300 miles on it. The water ports have been modified to provide a boost/vacuum signal. These will need capped off with 1/8"npt plugs if not using. $400 plus shipping
