Intercooled88s
Moderator
Compare prices, I'm usually the cheapest vendor on Turbobuick selling used parts!
-All prices do not include shipping, unless stated.
-Brand NEW still in the plastic 85-87 GN Front PUI bucket seat
covers(drivers and passengers seat, upper and lower) $300+shipping
or picked up
-New ABS Rear Bumper fillers $190
-New Fiber glass rear bumper fillers $140
-87 Grand National Engine 100% complete, runs great $2500
-8.5 Non Posi complete drum to drum $600
-Brand NEW still in the plastic 85-87 GN Front PUI bucket seat covers(drivers and passengers seat, upper and lower) $300 picked up
-New tranmission shifter cable(after market) $18
-Huge rear sway bar $75
-Hot Air(84-85) conversion kit to Intercooled(86-87) $1800 Includes almost all the stock 87 parts needed to convert over to intercooled, E mail for parts list
-7.5 posi rear end 3.73 gears complete drum to drum $350
-109 turbo block std bore $300
-Good std/std turbo crank $300
-8.5 Posi unit from a 87 GN $225
-86-87 Engine wire harness(no injector harness) $200
-86-87 Intake manifold(lower and dog house) thats been painted $160
-84/85 GN front air dam $50
- 87 turbo short block std bore $800
-New after market cruise control shifter lever $30
- Dutt style drive shaft loop $20
-Dash plaque for a GN in driver condition $40
-86-87 stock turbo, very little play $200
-84-85 stock trubo, very little play $100
- 84 GN front and rear seats(leather and cloth) need to be recovered $200
-86-87 T-type rims(no center caps) $300 for 4 or 1 for $100
-BRF 200 4r $500
-NOS Turbo 6 emblem $50 Free shipping
-Autometer Boost gauge with A pillar single pod $25
-86-87 original MAF(not Rem.) $90
-86-87 AC compressor $75
-86-87 Belt tensioner $75
-87 Intake manifold(lower intake and upper dog house, with metal waterlines) $200
-8445 heads Rebuilt with around 20k on them $100
-87 Engine harness with inj harness $230
-Turbo shield $40
-Rad hold down plate $30
-Front license plate bracket $20
-86-87 Air dams $55
-Doors $400 for set(1 pass and 1 drivers) they are manual windows and manual locks have just the start of surface rust on under side. Pick up only, I wont ship these.
-Vac brake set up $100+shipping(master cylinder, power brake booster, and correct pedal)
-87 442 Passenger side New rear quarter -Make Offer
-gray 87 442 bucket seats $200
-locking T-tops $200 a set
-84-87 Regal/T-type header panel(has hole for emblem) with good black paint $200
-84-87 Nice Header panel (Hole for emblem has been filled) $200
-GN driveshaft $75
-Stock 109 Turbo long block(120k) $1100
-87 GN 109 short block, .040 Cast pistons, .010/.010 turbo crank, never run $800
-86 NA 3.8 Engine complete runs good has 109 block $350
-84 NA 3.8 Engine complete runs good 290 block $250
-84 turbo Regal block .030 over $150
-85 Turbo Regal Block .030 over $150
-109 turbo block .030 over $150
-109 turbo block .060 over $100
-Turbo crank(Std/Std but will need to be turned at most .010/.010) $250
-Under drive crank pulley and alt pulley $40
-16" Western wheels GNX style rims $350 for set of 4
-86-87 T-type center caps(Tri shield) $40 Each
-86-87 T-type wheels(set of 4) no center caps $300
-85-87 GN steering wheel $100 no horn ring/center
-84/85 Turbo has some up and down play but works normally $100
-Nice set of GN tail lights with blackout trim $160
-84-86 GN Power seat track assembly $150
-Floor brackets for console $30
-Regal doors(They have very little surface rust on under side) $150 picked up only
-Floor pan for bucket seat car $150 picked up only
-Rear quarter $150 each picked up only
-Rear frame rails $100 each
-Front frame rails $100 each
-Control arms(Front lower)$60
-Control arms(Front upper)$30
-Motor mounts(metal, frame mounts) $35
-Turbo crank(.010/.010) in nice condition $200
-NEW Felpro gaskets(2 head gaskets 8723pt-1, 2 cork valve cover gaskets,2 Exhaust manifold gaskets) $35
-84-85 Flex cooling fan $10
-85 Power steering pump(For car with power master) $30
- trans cooler $20
-B body spindles $50 for pair
-85 Maroon bucket seats $200 good condition
-85 Gray bucket seats $200 good condition
-Maroon shifter handle $25
-Blue shifter handle $25
-Crank window regulators $50 for both doors
-Dash vents(with nice chrome) $20 each
-Nice Gray card board and cloth inserts(under quarter windows) From 85 T-type $30 for both
-Gray dash pad with a small hole drilled at the lower right of the drivers seat(Its not even noticable) $75
-Visors good for cores(non mirror) $20 a set
-Chrome marker light $35 each
-Both front head light bezels(need to be painted) $70 for both
-Rear center filler(The part that the rear license plate bracket attaches to) $30
-Pass remote mirror bracket(Just the bracket that attaches to the dash) $15
-NOS black plastic seat track cover for rear right side(GM part # 20023766) $20
-Frame in good condition $200
-heater box shield $15
-84-85 Shield to cover heat hoses $15
-bumperette rubber strips in good condition(used GM not after market) $20 each
-Stock factory lighter $8
-Stock Battery hold down $10
-Connecting Front Brace $25
-Front frame braces(underside) $25
-Plastic Brackets to mount front air dam $30 for 2(For both sides)
-Good hood shocks $10
-Stock turbo inlet bell $20
-86-87 engine hoist bracket(on intake) $20
-87 gray cloth Limited front and rear seats $200
-87 gray column (shift on column) $100
-87 Split bench seat power seat track assembly $100
-Original GN Quarter extensions for car with spoiler $40
-84 Red upper door panels $80 minus chrome/gray strips $50
-Grey T-type upper door panels no chrome strips $50
-87 Maroon upper door panels $50
-Drivers side Blackout head light bezel $40
-Chrome head light bezels painted black $40 for both
-Black trim Marker lights $40 each
-Blackout wheel well moldings $60 each
-Chrome(Regal) wheel well trim moldings $45 each
-84-87 T-type header panel with hole filled $150
-84-87 T-type GM header panel, has some small imperfections $125
-84-87 Grand National GM header panel, has imperfections $125
-Passenger remote mirror(needs paint) $60
-87 GN seat belt set(10 pieces) $120
-84 GN steering column with tilt/cruise $150
-Maroon steering column with tilt/cruise $150
-87 GN grey column with tilt/cruise $150
-87 grey column(shifter on the column) $100
-84 Blue column(shifter on column) $100
-84 tan bucket seats $250 with rear seats $300
-86 blue 86 442 bucket seats $200
-85 Gray 442 bucket seats $200
-Gray Monte SS bucket seats $200
-85-87 Gray concert sound lower door panels $100
-GN Dash Plaque $75
-84-86 T-type dash plaque $50
-86-87 Upper intake(dog house) $30
-86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100
-86-87 bare throttlebody $40
-86-87 Up pipe $25
-86-87 Cruise control assembly $40
-86-87 Water pump pulley $25
-86-87 Main accessory bracket $70
-86-87 Y bracket on back of Alt $35
-86-87 Flat Y bracket on front of AC compressor $35
-86-87 Intercooler brackets $25 each
-86-87 Coil bracket ( The horse shoe shaped bracket) $30
-86-87 Power steering res. bracket $20
-86-87 Power steering pump $70
-87 GN Electric fan $50
-84 rad shroud $30
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
-86-87 T-type wheels $100 each
-87 locking t-tops $250 a set
-84-85 Non key locking t-tops $150 a set
-Astro roof complete assembly with wire harness, switch etc. $200 wont ship
-Bigger then stock front sway bar $70
-Fuel sender/fuel hanger(analog gauge) $60
-BQ tranny $250
-Rebuilt BQ tranny $400
-D-5 convert $50
-87 chrome grill painted black(looks good) $100
or picked up
-BRF 200 4r $500
-Turbo shield $40
-86-87 Air dams $55
-GN driveshaft $75
- trans cooler $20
-GN Dash Plaque $75
-86-87 Up pipe $25
-84 rad shroud $30
-BQ tranny $250
-D-5 convert $50
