realspartan
- Dec 14, 2008
Would like the 86-87 stock maf, How much shipped to Montreal Canada zip code H4M2Y7? Thanks.
SignUp Now!It was stolen at the paint shop...
I need the. Trim piece that goes behind the back seat near the back glass for an 87 grand national , forgot that I needed this ... It's gray
Intercooled88s said:I have metal trim piece behind the back seat that holds up the head liner. I dont have the clips, just the trim piece it self. Its gray and its in good condition. $15+shipping for it. Probably the best way to ship it would be in a tube.
pics to platinumperformance60@yahoo.com
thanks
sent you a pm on trim piece, 15 sounds great, shipping cant be that bad, to 77546?
whatever it is, ill cover it, thanks for the help sir!!!
Paypal complete .
Compare prices, I'm usually the cheapest vendor on Turbobuick selling used parts!
-All prices do not include shipping, unless stated.
-86-87 GN center caps $25 Each
-87 GN dash pad $120
-85-87 GN gray dash speaker cover, in really nice condition(no cracks looks close to new) $200
-Driver quality 86-87 GN wheels $75 Each
-Power Master $300
-NOS black wheel well moldings(both front and drivers rear) $100 Each
-New ABS Rear fillers with minor damage(easily repaired) $100
-New ABS Rear Bumper fillers $200
-8.5 Non posi 3.73 Rear end $600
-87 gray 442 console $175
-Mega shifter for Turbo 350 $75
- gray 442 bucket seats $250
-GM crate motor 350 block # 10066036 4bolt mains Edelbrock carb and intake, headers, comp cam 1.6 rockers etc. $800
-nice set of 85 Maroon bucket seats $300
-Brand NEW still in the plastic 85-87 GN Front PUI bucket seat
covers(drivers and passengers seat, upper and lower) $300+shipping
or picked up
-87 Grand National Engine 100% complete, runs great $2500
-TR Custom New style Big mouth cold air kit,chrome has some small spots of rust but its in over all good condition NS its conplete $80
shipping included within the US
-New tranmission shifter cable(after market) $18
-Hot Air(84-85) conversion kit to Intercooled(86-87) $1800 Includes almost all the stock 87 parts needed to convert over to intercooled,
E mail for parts list
-Turbo Riviera Turbo $200
-109 turbo block std bore $300
-Good std/std turbo crank $300
-8.5 Posi unit from a 87 GN $225
-86-87 Engine wire harness(no injector harness) $200
-86-87 Intake manifold(lower and dog house) thats been painted $160
-8485 GN front air dam $50
-New after market cruise control shifter lever $30
- Dutt style drive shaft loop $20
-Dash plaque for a GN in driver condition $40
-86-87 stock turbo, very little play $200
-84-85 stock trubo, very little play $150
- 84 GN front and rear seats(leather and cloth) need to be recovered $200
-86-87 T-type rims(no center caps) $300 for 4 or 1 for $100
-BRF 200 4r $500
-NOS Turbo 6 emblem $50 Free shipping
-Autometer Boost gauge with A pillar single pod $25
-86-87 original MAF(not Rem.) $90
-86-87 AC compressor $75
-86-87 Belt tensioner $100
-87 Intake manifold(lower intake and upper dog house, with metal waterlines) $200
-8445 heads Rebuilt with around 20k on them $100
-87 Engine harness with inj harness $230
-Turbo shield $40
-Rad hold down plate $30
-Front license plate bracket $20
-86-87 Air dams $65
-Doors $400 for set(1 pass and 1 drivers) they are manual windows and manual locks have just the start of surface rust on under side.
Pick up only, I wont ship these.
-Vac brake set up $100+shipping(master cylinder, power brake booster, and correct pedal)
-87 442 Passenger side New rear quarter -Make Offer
-gray 87 442 bucket seats $250
-locking T-tops $200 a set
-84-87 RegalT-type header panel(has hole for emblem) with good black paint $200
-84-87 Nice Header panel (Hole for emblem has been filled) $200
-GN driveshaft $75
-Stock 109 Turbo long block(120k) $1000
-87 GN 109 short block, .040 Cast pistons, .010.010 turbo crank, never run $800
-86 NA 3.8 Engine complete runs good has 109 block $350
-84 NA 3.8 Engine complete runs good 290 block $250
-84 turbo Regal block .030 over $150
-85 Turbo Regal Block .030 over $150
-109 turbo block .030 over $150
-109 turbo block .060 over $100
-Turbo crank(StdStd but will need to be turned at most .010.010) $250
-Under drive crank pulley and alt pulley $40
-86-87 T-type center caps(Tri shield) $40 Each
-86-87 T-type wheels(set of 4) no center caps $300
-85-87 GN steering wheel $100 no horn ring center
-Nice set of GN tail lights with blackout trim $160
-84-86 GN Power seat track assembly $150
-Floor brackets for console $30
-Regal doors(They have very little surface rust on under side) $150 picked up only
-Floor pan for bucket seat car $150 picked up only
-Rear quarter $150 each picked up only
-Rear frame rails $100 each
-Front frame rails $100 each
-Control arms(Front lower)$60
-Control arms(Front upper)$30
-Motor mounts(metal, frame mounts) $35
-Turbo crank(.010.010) in nice condition $200
-NEW Felpro gaskets(2 head gaskets 8723pt-1, 2 cork valve cover gaskets,2 Exhaust manifold gaskets) $35
-84-85 Flex cooling fan $10
-85 Power steering pump(For car with power master) $30
- trans cooler $20
-B body spindles $50 for pair
-85 Maroon bucket seats $200 good condition
-85 Gray bucket seats $250 good condition
-Crank window regulators $50 for both doors
-Dash vents(with nice chrome) $20 each
-Nice Gray card board and cloth inserts(under quarter windows) From 85 T-type $30 for both
-Gray dash pad with a small hole drilled at the lower right of the drivers seat(Its not even noticable) $75
-Visors good for cores(non mirror) $20 a set
-Chrome marker light $35 each
-Both front head light bezels(need to be painted) $70 for both
-Rear center filler(The part that the rear license plate bracket attaches to) $30
-Pass remote mirror bracket(Just the bracket that attaches to the dash) $15
-NOS black plastic seat track cover for rear right side(GM part # 20023766) $20
-Frame in good condition $200
-heater box shield $15
-84-85 Shield to cover heat hoses $15
-bumperette rubber strips in good condition(used GM not after market) $20 each
-Stock factory lighter $8
-Stock Battery hold down $10
-Connecting Front Brace $25
-Front frame braces(underside) $25
-Plastic Brackets to mount front air dam $30 for 2(For both sides)
-Good hood shocks $10
-Stock turbo inlet bell $20
-86-87 engine hoist bracket(on intake) $20
-87 gray cloth Limited front and rear seats $200
-87 gray column (shift on column) $100
-87 Split bench seat power seat track assembly $100
-Original GN Quarter extensions for car with spoiler $40
-84 Red upper door panels $80 minus chromegray strips $50
-Grey T-type upper door panels no chrome strips $50
-87 Maroon upper door panels $50
-Drivers side Blackout head light bezel $40
-Chrome head light bezels painted black $40 for both
-Black trim Marker lights $40 each
-Blackout wheel well moldings $60 each
-Chrome(Regal) wheel well trim moldings $45 each
-84-87 T-type header panel with hole filled $150
-84-87 T-type GM header panel, has some small imperfections $125
-84-87 Grand National GM header panel, has imperfections $125
-Passenger remote mirror(needs paint) $60
-87 GN seat belt set(10 pieces) $120
-84 GN steering column with tiltcruise $150
-Maroon steering column with tiltcruise $150
-87 GN grey column with tiltcruise $150
-87 grey column(shifter on the column) $100
-84 Blue column(shifter on column) $100
-84 tan bucket seats $250 with rear seats $300
-86 blue 86 442 bucket seats $200
-85 Gray 442 bucket seats $200
-Gray Monte SS bucket seats $200
-85-87 Gray concert sound lower door panels $100
-GN Dash Plaque $75
-84-86 T-type dash plaque $50
-86-87 Upper intake(dog house) $30
-86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100
-86-87 bare throttlebody $40
-86-87 Up pipe $25
-86-87 Cruise control assembly $40
-86-87 Water pump pulley $25
-86-87 Main accessory bracket $70
-86-87 Y bracket on back of Alt $35
-86-87 Flat Y bracket on front of AC compressor $35
-86-87 Intercooler brackets $25 each
-86-87 Coil bracket ( The horse shoe shaped bracket) $30
-86-87 Power steering res. bracket $20
-86-87 Power steering pump $70
-87 GN Electric fan $50
-84 rad shroud $30
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
-86-87 T-type wheels $100 each
-84-85 Non key locking t-tops $150 a set
-Astro roof complete assembly with wire harness, switch etc. $200 wont ship
-Bigger then stock front sway bar $70
-Fuel senderfuel hanger(analog gauge) $60
-BQ tranny $250
-Rebuilt BQ tranny $400
-D-5 convert $75
-87 chrome grill painted black(looks good) $100
I need a lower intake manifold for an 87 GN if you still have one. email is osbron5@hotmail.com[/quote]
Sent you an E mail.
ENGINE PARTS:
AC compressor(84-85) $40
AC lines(84-85) $40
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(85 Turbo to intake adaptor) $40
Adaptor(Oil cooler adaptor with nut) $35
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $25
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $80
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover)
$20
Block(109 Block) $250
Cam position sensor just the lower part(no cap) $30
Cam position (sensor with cap) $65
Coil pack(84-85) $40
Coil pack(86-87) $25
Control module(84-85) $50
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $50
Dip stick and tube(84-85 dipstick and tube) $30
ECM(84-85 ECM) $40
EGR plastic cover $5
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $40
Heads(stock 8445 heads needing rebuild) $50 a set
Injector harness(84-85) $35
Intake manifold(86-87 Upper intake manifold)$35
Intake manifold(84-85 GN intake) $40
Intercooler $45
Intercooler brackets both for $40
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Oil pan(Turbo oil pan) $40 each
Power steering pump(86-87) $70
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$20
Rock arms+shafts(stock, complete set) $35
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttlebody(86-87 Throttlebody bare) $35
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Valve covers(set of 2) (84-85) $30
Valve covers(set of 2) (86-87) $50
Vapor cannister $10
Wire harness(84-85 engine wire harness) $150
INTERIOR:
I have every color interior part including green.
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Concert sound speaker covers(84 GN) $50
Console shifter plate(Plate on console that goes around the shifter)$25
Dash pad no cracks(grey or Maroon) $120
Digital dash gauge cluster $200
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $100
Gauge cluster(Digital) $200
Radio(Stock GN radio with cass, no EQ) $40
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hardtop car $40 for both
Seats(87 GN Front bucket seats need recovering) $200
Shifter $35(84-87 GN, needs T handle)
Steering wheel(good to have recovered) $40
Steering wheel(Tri shield GN horn center $40 no ring)
Steering wheel(T-type horn center $30 no ring)
Steering wheel(T horn center $30 no ring)
Surround(Gauge surround) $30
Surround(radio surround) $20
Third brake light(Grey, red, Maroon, or blue Third brake light)$20 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, grey and blue $25 for each
piece
Body Parts:
Blackout trim for front windshield $30 each piece or $75 for all 3
Blackout trim for rear window $30 each piece or $50 for all 3
Blackout trim around the door windows $30 each piece
Blackout Drip rails(hard top) $50 for both
Blackout trim, T-top boot shaped trim that the T-tops lay on $60 for both
Bumper(GN Rear black bumper) $100
Bumper reinforcement(Alum. Front bumper reinforcement)$90
Bumper reinforcement(Alum. rear bumper reinforcement) $70
Front bumper shocks $25 for both
Rear bumper shocks $25 for both
Fenders(84-87 GN fenders(GM)) $100 each
Grill 87 GN Grill $200
Grill 86 T-type grill $50
Grill emblem(87 , says "Buick") $15
Hood(GN hood) $150-$250 (pick up only)
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Lock set(all 3 locks with key) $30
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror,non remote)$20
Mirror(Passenger Mirror, Remote) $65
Quarter windows with blackout trim $150 for both sides
Tail lights with blackout trim $160
tail lights with chrome trim $80
Wheel well(Drivers Turbo plastic wheel well) $100 each
Wheel well(Passenger Turbo plastic wheel well) $150 each
Any other blackout piece e mail me I have them all
Misc:
Antenna base nut and spacer for Power antenna with black trim $10
Control arms(Front lower)$50
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $120
Heater box shield $15
PowerMaster to firewall adaptor(bracket) $30
power trunk mechinism $20
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
84/85 Tranny dip stick and tube $40
86/87 Tranny dip stick and tube $45
Transmission oil pan(Stock 200 4r tranny pan) $25
84-85 T-type wheels $40 each or 4 for $120
windshield wiper motor $40
Body Parts:
Misc:
