dyno sheet build up
CopGn,
I'm not sure how indepth you need me to be, but hear goes.
Stock short block with stock rods, stock pistons, and no caps crank is 10-10 with a stock flexplate and balancer
210-205 hyd. flat tappet cam about .430 average lift (I can supply actual specs if needed)
ported iron heads (by me) with stainless valves
steel shim head gaskets with the special goo
T&D roller rockers at 1.55 ratio
volt booster
walbro 340 single pump in tank
stock intake ported to heads with stock throttle body
70mm PTE doghouse
V4 stock loc. stretch intercooler
50 lb injectors with street chip from pte (I think about 18 deg. timing at about 80 cycle duty I'd have to look to be sure)
3000-3200 presision converter with lockup
PTE 51 with 63 housing (for sale currentally)
houston 3 inch down pipe uncapped
Ran a verified 19lbs of boost that day with straight cam 2
car weighs 3750 with me in it
runs consistant 11.60's with a best of 11.36 at 117.81 with that tune up 1.61 60ft with drag radials (have slicks on for next season in pictures)
I did all the work on this engine myself. You can e-mail me direct if you would like for anything I missed at
Tweeked6@aol.com
Axle, thanks for the great pics!!! (and noticing my little torque numbers)
