25# of boost???
ulose2av6
well here is a real problem.maybe. Is it possible my boost guage is not working properly I am spiking near 25#of boost and my motor is not detonating. I am running pump gas and i have no knock retard on the scanmaster.or am i detonating real badly and dont realize it.
If you are running 93 octane with no alky or anything else then I can't see how you could run anywhere near that high, even in very cold weather. That's just alot of boost man. The common boost level associated as being the highest on straight 93 usually runs around 17 psi. I would definitely get the car checked good before flooring it again. If everything checks out fine and you are actually running 25 psi on straight 93 then send me a 50 gallon drum of that stuff man.:D
