Inexpensive convertors
Speaking from experience, the most expensive convertor is usually the cheapest one you could buy outright trying to save a few $$$ during a rebuild.
If you are going to go through the expense of rebuilding the trans on these cars, even a fairly stock setup, it might be prudent to look for a good quality convertor even if it costs a bit more than some of the least expensive ones out there. This is especially true if there is even the remotest chance of you trying to upgrade other stuff like the turbo, intercooler, etc.. down the road.
Building a good convertor takes quality parts and labor that aren't cheap, and while you might get away with something cheaper in the short run, I had the unfortunate experience of trying to save a little $, only to end up having some of the convertors fins break off after a few thousand miles, and destroying the transmission, on a near stock setup that I don't race or take to the track.
Maybe I was unlucky, but these cars produce a lot of power even stock, and I assume with alchy you are running more boost than stock, so that puts extra stress on stuff that could end up breaking. Do a search on transmissions and torque convertors + failure and you'll see I'm not the only one that has found this out...
Hope this helps you
Billy
