3-4 Accum position
Blown&Injected
Hi Guys:
The ASTG says to note the position of the spring and piston as they are not all the same - it looks like the position doesnot matter except for the piston being put in up or down - What's the deal?
TIA
if you put the spring in the hole first and then the piston you now have no accumulator and this is not good ,it is a means of firming up the shift but it has side effects that are always undesirable ,the piston goes in first then the spring .www.ckperformance .atsg is not very good at racing automatics either .
