3.5 maf and translator
crazygn
10's here i come
if you look at my sig do you think it would work good with my set up that i run , i will be going to a bigger turbo in the winter, maybe 60's or a 70. Is the 3.5 to big for what i run. And what kind of chip would i have to run.
thanks guys :)
If you get the Translator Plus, you will be able to adjust the idle and WOT spark (Advance or Retard). As well as the idle and WOT fuel. The Translator will only adjust the fuel.
I have and like the Extender Chip. Might as well get the extension cables to you can put the translator inside the car.
3.5" works just peachy on my combination, which isn't that far from yours. There was a noticable, and measurable increase in performance when I went from the 3" LT1 to the 3.5" LS1.
