3 8.5 10 bolt rears
forcefed3.8's
Buckeye Bullet
I have 3 GN rears I would like to sell.
The first is a 60,000 mile G80 posi factory 3.42, flash rust, no heavy scale $850
The second has 79,000 miles, factory 3.42, non posi, but has a Powertrax locker (I can pull the cover and verify, as it has no fluid from when I checked to see.) Rusty, not too bad, looks worse than it is, lines might need repalced $600
The third has very little flash rust, but has a bent axle tube (can be fixed from what I was told), missing some brake parts, no guts, I can include 2 stock GN axles, $150
pick up at 44039. Thanks.
rearend
im interested in the one for $150. can you send me pictures of how bad its bent. does it still have the correct carrier caps. would it be any cheaper without the axles? all i really need is a bare housing with the carrier caps. Racer8686@aol.com, thanks Jeff Smith. 228 806 7770
pics
