3.8 Buick motor identification?
turbo1962
I have a Buick Motor and i was wondering if anyone could tell me what year this motor is and what it came out of. The number I found is 255241A0 or could be 25524140. The block is red, I have never seen a red block with black heads. Has turbo on top
according to gnttype.org you have a 1985 block for RWD, should have 8445 heads, doesnt say it was used on a turbo car, maybe some did a conversion of a 3.8L carbed engine? the 25520329 was the turbo block correct? hth
Buick V6 History
It has a 20 bolt oil pan?
1985 switched to a 20 bolt from a 14 bolt.
i pulled the stuff below from the website.
1985
Oil pan went 20 bolts from 14 bolts
New block, front cover and oil pan
Torque-to-yield non reusable head bolts
So it could still be a non turbo motor?
i have no personal experience with those years, but from what i have read, that "140" block was for a 85 RWD N/A engine, and the "329" block was the turbo block in 85. in 86-87 they had the "109" blocks
So that still doesn't tell me if it is a turbo motor?
not unless there is someway to use the last numbers of the VIN to find out the options of the car, i guess it is a production code of some sort. maybe see if a local buick dealer could look the last 8 of the VIN up?
Turbofish38 would know this for sure.
Maybe PM Eric & ask him? He is on this board isnt he? If not he's on Turbobuick.com daily.
