The old Kenne Bell Mark 1L cam had .420 lift and would work without cutting the guides and the stock springs could be used, so it looks like the 252H would be your best bet at .425 lift. It is very similar to the KB grind, which showed a 14 rear wheel HP gain over the stock cam on a test. If you go any larger and have to pull the heads, the springs and retainers should also be changed. Comp has what they call a K kit that has cam, lifters, springs, retainers, valve stem seals, and a standard timing chain and gears. I would probably go for a roller chain instead of the standard timing set. You should remove the chain tensioner with a roller chain. It may chew it up. I would go for the 252H if you don't cut the guides. If you pull the heads and cut the guides, pocket port them, and replace the springs and retainers, I would use a cam similar to the 260H. You will probably get about 200 HP out of your combination with the 260H. The 3.8 only had about 110 HP stock. If you go to a more radical cam like the 268H, you will loose some low speed driveabilty, but it will sound like you have a cam. Be conservative with your cam choice unless you can live with an engine that idles poorly.
