3.8 short block FS
Jeff Rand
109 block with two steel center main caps that has been line honed with ARP studs. Rods have been polished and the big end re sized with ARP bolts. J&E pistons .030" over pressed fit. Main clearance .0019" and rods .002". New cam bearings. Stock crank 20/20 that has been nitrated. Blocked has also been decked. Two front oil passages have been drilled and tapped with correct plugs. All the freeze out plugs replaced. I built this block to install in my car but I came across a stroker setup and decided to sell it. $1600 add $175 if the RJC pan is included otherwise I have a stock pan. I could assemble the long block if all the parts are supplied to me.
Jeff
When I get a chance I could shoot some pictures.
