434nova
- Sep 30, 2013
I am in the process of installing a alky control kit on my car. It comes with a harness that plugs into the tps and on the other end it has a map plug and a green wire along side of it. I am running a xfi and have the 3 bar map inside the car. Do I need to hook up that map plug to my 3 bar or do I leave it unplug and just hook up the green wire to the pac controller. I dont known if I have to disconect the map sensor harness from the fast and use the one supplied with the alky kit. Thanks
