Impossible "IF" you have 5 volts on gray. Possible if you have 12 volts on gray. If you have 12 volts on gray, then your not wired correctly.
You can not have higher voltage on the output of a sensor than what supplies power to it. Think of it like your TPS. If your supply is 5, then the most is reads is 4.xx. If your supply was 10.. then it could only go to 9.xx.
If the gray wire has 5volts.. then its impossible to have higher than 5 coming from the sensor.
Or you hooked up 9 volts directly to the green wire from some other source not map sensor.
You need some electrical help with that car
