3 bar Map sensors
That video is for testing a 1 bar map.
The 2bar is 2.4 key on.. 0-2.4 in vacuum, 2.4-4.8 in boost.
3 bar is 1.6 Key ON. 0-1.6 in vacuum. 1.6-4.8 in boost.
Example 3.2=14.7 PSI. It will track approx .1 volt per psi.
Many times when a MAP sensor goes bad its signal gets noisy with vibration. It is very hard to pick this up on a simple meter. A scope is really needed to see this type of problem.
bringing back a old thread I know, but has anyone used the MSD from advance auto parts? part number 2313. I would use Erik at turbo tweak but he is sold out at the moment and I have an advance gift card so I might as well use it.
Should work, I stock the 3 bar in case Advance can't get it.
Just ordered the MSD 2313. $56 with coupon code including shipping. I will let yall know if it works.
