3, V6 motors can bring to Bowling Green
N2BUICK
TurboBuick.Com Supporter!
I have one 4.1 V6 short block $750
One 4.1 Stage2 bare block $750
One 4.1 bare block $200
I do not have a history on there motors. The only thing I know, i was told, the Stage2 motor has issues. ???
The 4.l short block, 25506484, had ,040 pistons, a 877 turbo crank. Appears to have stock rods. It does have steel center main caps and studs. No cam or heads.
Turns okay, no appearant loose parts.
The Stage2 bare block, 26600016. Note there was epoxy material in the upper wall of the lifter valley. I dug out the material, there is metal under it. There appears to have been a repair of some sort. The area is directly under the the lifter path.
No guarantees are made on any of the three motors.
The bare 4.1 appears to be a stock appearing block.
I'm posting many pics. The stock 4.1 is first.
More motor pics, Stage2
More pics 4.1, short block
I failed to mention, these engines are in the Oklahoma city metro area.
The Stage2 block bore is 4.038 "range"
