I have had a problem for a long time with the car trying to die off the light if i just step on it. Now that i have the scan tool , but the cord needs to be fixed, i can read that the maf is at about 140-180gps. Now iam getting a code on the turbo link that i have a low maf or map sensor. These reads where with a ta54 at 20+psi. Now that i put the ta49 on it is breing the code up now , like its pulling even less air. I did the tap test and nothing , the motor shakes a lot , if i rev it some it will come back down and die most of the time. I also pulled the plug on the maf and it seems to idle a lot nicer but cant rev it or it acts as it has a miss. Also keep getting a code for running to rich.
does this sound like a bad maf, i just paid 110.00 for it less then a 1000 miles ago.
