300M Input Shaft
charliep
How can you tell the difference between the stock input shaft and an aftermarket version????
Here is a good example of a billet input shaft versus stock. CK Performance shaft on the bottom and stock on top. No relief cut below splines to promote stress risers. Smooth transition from splines to shaft. Longer spline length. You can't see in this pic but the hole in the end of the input where the little checkball capsule goes is smaller diameter and eliminates the capsule.
Thanks Gneric. That is exactly what I'm looking for. I am supposed to have a 300M shaft and I want to make sure before putting it back together.
