3200 stall to much for my combo?
bpman1234
so I got a 3200 10'' tci .is it to much for my stock motor on e85 with 80 injectors and a te60 turbo .mostly street and highway.dont have the doe right now to get new one .but I have these 2 sitting there looking at me also have that restalled d5 2800
Since you have both,try them and see.the flash stall is what I would be concerned with.you can manually lock a d5 which will put the car into correct rpm in 3rd.i don't know if you can lock a tci 10inch but at 3200 you would need it locked up top or you will blow through it upstairs.
Yea decided to put the d5 in till i can grt get a quality converter. Thanks again to alll.
Sent from my LG-K373 using Tapatalk
