325/50/15's
Underboost
Mr. Dull
Does anyone know what Backspace is used with a 10''x15'' rim when notching and going with the 325/50/15 Dr's? Any pic's?
Thanks in advance ;)
depends on the notch ... we run 5.5 but use a 5/16 spacer ... don't think anyone makes a 5 1/4" backspace .. those tires are HUGE :eek:
That looks perfect Grumpy Nice! ;) See I have 5 BS now with 1/2 spacer for my 275/60/15's but was wondering what that would look like with the 325/50/15's and no spacer. I think the tire will stick out to much. :frown: My Aluma Star 2.0's don't come in half sizes.:mad:
i have 5inch bs on mine and the tire sits just inside the fender. no rubbing issues either.
That looks good also DANMAN. Ok maybe I'll do the 5 bs now. :biggrin: Keep the pics coming guys. The 325's look Awesome!
Did you guys in the high 9's notice a big difference in traction while cruising on the street with the 325's compared to the 275's? :smile:
Danman, what shocks and springs are you running?? It looks like you have a good distance from the wheel well to the top of the tire going. This is probably why your 5" B.S. is not causing problems. Did you roll the lip?
And I second T Spool, see a lot of 5.5" B.S. for notched 10 inch guys.
I had the flares widened 1 1/4" so I am going to run a 1/4" or 1/2" spacer with longer studs this Spring with the 325/50 on a 4.5" B.S. :biggrin:
the springs on my car are hotchkis and the shocks are just regular old 3way adjustable drag shocks. i actually took and cut the fender lip out and smoothed the inside. the car also has airbags in the sprins to keep it from squatting too much.
Grumpy
Dan I am dropping my GN off at your house for one week. It better run low 11's when I get it back. All I have is 2 dollars. Do what you can. Thanks, AJ
