34mm hollow sway bars
T Spool
I have (4) ready to ship!
Sandblasted and professionally sprayed satin black, they are good as new.
These are even lighter than the 36mm bars by about 2 lbs so you will save over 10 lbs off the front end while substantially improving handling.
34mm poly bushings are available from Energy Suspension for @ $15 or less.
$75 shipped to the 48. I prefer PayPal mlaforest@aastrom.com
How much better is the 34 than the stocker??? and also compared to the 36??
I sold 2 34mm bars to a customer last month and he reported good results in the feedback section http://www.turbobuick.com/forums/showthread.php?t=197117 Personally, I couldn't tell any difference between the 34 and 36 so I am keeping a 34 because I am all about weight savings. Both bars compared to the stocker are very noticeable improvements in body roll and cornering, even with my 3 1/2 inch Draglites up front it is significant. I sell both sizes, but seems that most people want the biggest and baddest and go for the 36, but after my own testing I am keeping a 34.
Hey T Spool, Thanx for the reply! Can you shoot me a link for the bushings? Would this work with tubular a arms, etc.?
The Energy Suspension part # is 35131. I would just order them from your local auto supply store that carries that brand. Murrays' has them here in MI. ES link is http://www.energysuspension.com/pages/cam1.html 82-92 Camaro/Firebird 34mm bushings is what you want. I can send a used set of bushings if you would like. I don't have experience with tubular a arms, but if your stock bar bolts up to them these should to since they are a direct bolt in. I cannot be certain however.
Another link http://www.energysuspensionparts.com/proddetail.asp?prod=3.5131
