350 turbo trans....??
JASON
THE ORIGANL FREAKZILLA
I havent hade any problem with the trans infact I hardydrive the car and when I parked it it had no prob. about a week ago but i pulled it out tonight just to go around the block and it slips when going into 2ed any ideas what this might be ?...thanks
If it seemed to happen rather quickly, you may have a fractured/broken intermediate roller-clutch outer race.
ok.....im a dummy what is that?
The intermediate (2nd gear) clutches are in the front of the case, right behind the pump. The clutch pack engages the case on the outside, and the intermediate sprag outer race on the inside. The intermediate sprag assembly, consisting of an inner race, a roller clutch sprag, and an outer race, is located on the direct (3rd gear) drum. It is the weakest part of a 350 turbo transmission. Most often, if you have a sudden failure in second gear, the sprag is broken. Usually, it won't slip, you just don't have 2nd gear at all. It is possible you have blown a lip seal or cracked a piston, but a sprag failure is most common. Rarely, you find that a constant excessively harsh 1-2 shift will cause the splines on the inside of the clutches to strip.
The weakness of the intermediate clutch in a 350 is why I rarely suggest it be used in a performance application, because to make it strong enough costs about $450. A 350 is best replaced once you begin breaking sprags. Greg's company, TCI, does make an outer race that is heat treated, and gives an affordable improvement, but it will not make a 350 nearly as strong as it needs to be in many cases.
OK. In that case, you already have the heat-treated race in there. Not to say that it didn't fail though because, unfortunately, some still do. Does the transmission have any other symptoms?
. Does the transmission have any other symptoms? [/B]
no, so far that is the only thing I have seen wrong I'll get it out again tonight and drive it a little to see..last night it done it as soon as I pulled it out of the garage. so it wasnt put under any strain when it started:confused:
