350 turbo
ricturbo
my 200r4 is slipping again .does anyone know if 350 trans will mount straight to my engine ? 86 gn thx...
You will have to find a bop th350 or get an adapter plate for a Chevy th350.
Who is building your 2004r? How fast are you going?
I have a 350 (BOP case) in mine as a back up trans, you will miss 4th gear, what rear end gears do you have? You will have to change cross member also. I love the trans for the "cheap" piece of mind. I had the trans built for 500 and I have beat it to death. My converter was 300.
Did you change your shifter to work with the TH350?
There has been a B&M mega shifter in since the day I got the car , i just change the little gear selector cover to fit the trans. Sorry can't answer that part.
