National Newb
- Sep 21, 2007
Just mounted up my 36mm fbody sway bar that I got off a TB member... has the two holes at the end and definately is hollow.... but when I mounted it up... it sits under the frame rails a bit... like if you hit a big bump and it goes straight up it will hit the frame...
When I took it off again and laid it ontop of the stock swaybar, the fbody one is alittle narrower.
put the stock one back... and looks like it clears the rails...
any info would be gratly appretiated...
