36mm Sway Bar, Fabricated VC's, Biggie Oil Filter Adapter
Hot Air
E85 and S.E./Carolinas Moderator
Staff member
I have following for sale.
1. NOS GM 36mm hollow front sway bar for 1LE Camaro - $100 plus shipping
2. Fabricated aluminum valve covers (don't know if they will fit w/air conditioning) - $110 plus shipping
3. Biggie Oil filter adapter with 2 new NAPA gold oil filters - $35 plus shipping
Photos available.
Conrad Carter
North Carolina
Conrad: I'll take the swaybar, what other hardware will I need to install?
The sway bar is yours. Will check on the items needed to install and let you know tomorrow.
Conrad
I'm not Conrad, but I can answer your question...You'll need 36mm bushings for a 3rd gen F-body. You retain your stock brackets and end links.
According to my records (not infallible), here are the GM P/N's thaqt you need:
36mm sway bar bushing - a high durometer rubber with fiberglass liner (a 1LE number) - 14094389 (about $10 each in 2002)
Bracket for above that will fit holes in g-body frame - I used the bracket that I had taken off of my 96 Impala SS. Of course, the bracket would be the same if you looked under a 9C1 (Policer car) or a F41 (?) optioned Caprice from 94-96 and quite possibly much earlier. The attachment holes in the 1LE bracket didn't line up with those in my GN's frame. I wanted something that would "bolt on" without modification.
Conrad
ps...I went with Energy Suspension end links since they are poly and cheap ($15 pair). I am trying a slightly longer end link next week and will post P/N's once I try it out.
I found a GM P/N that I'm told will work...someone might want to try it...14041898 and let me know if it is ok.
Conrad
Everything is sold pending receipt of $'s.
Conrad
Conrad: you want to try to get together next weekend and wrap this up??
Kevin,
Let me check with the Missus and see when we will be headed that way. Adam is borrowing my motorcycle this week and he will have to get it back to me somehow or I will have to come get it. What is your timeframe for gettin it?
Conrad
No real timetable, just whenever we might be in the same general area at the same time, the week is pretty tough for me now with my new job/commute but I can pretty much meet anywhere,anytime over the weekends. I'll try and otuch base with you mid-week and we can figure it out then...
I'll fill you in later, but yes my days at performance are mercifully over, and I is enjoying the bejesus out of myself right now....just the gas bill is a bear!
If you're coming down to Connie's place, why not ride on down for some sheetmetal before Weaver gets everything else ;)
that's still on my "to do" list actually....this weekend work for you?
KH440 sent me $'s. What happened to everyone else?
Conrad
