3800 SC in Sandrail
Buicksandrail
Hello,
I am currently running an 83 3.8 turbo in my sandrail and it runs great. For my next sandrail, I would like to install a 3800 series II SC engine in it. Is this feasible? Besides the engine and harness, what else would I need to make this work? What computer? Is it OBDII? I will run a VW bus 4 speed trans. Any comments and suggestions would be greatly appreciated.
Thanks,
Trent
Do you know Ty Gardner up in Folsom? He's got essentially that with an S1.
We're running S2's in Fiero's on manual transmissions using the 94/95 ECM. Contact me if you need some help.
Terry
3800 sandrail
Just purchased a sandrail with a 1995 3800 series I SC engine. I am looking for some technical info on modifying the ecm. The person I purchase the sand rail from used a 1998 obcii pcm with a custom harness from Jim's Performance. They also bypassed the Vats, knock sensors and added a 2 bar map sensor. The problem I am having is at high rpm under hard acceleration I get a popping from the intake. After looking at the spark plugs I think I am getting a lean condition. Any info would be greatly appreciated.
