- Dec 15, 2002
An option for those in a similar situation.
I switched my oiling setup from the PTE Turbo Saver to the Turbo Protector while switching my turbo feedline to a -3an Earls 22" Braided Brake Line. I now have a GN that doesn't smoke.
Make of it what you will, but I was making a beef about the -4 feedlines and how the factory line was WAY smaller and it appears, at least for my setup, that the switch was needed.
Earl's Performance 63010122ERL - Earl's Performance Speed-Flex Brake Lines – SummitRacing.com
That hose might not be long enough if you wanted to swap out the -4 on the PTE Turbo Saver.
I mentioned in the past that I've been running a -3 feedline on a PTE6152S on my Turbo Talon for about 6 years now, no problems at all so I just borrowed that setup and it works. You don't need to swap out the Turbo Saver, just the -4 line.
