Ok, I've had a problem for awhile and I thought I figured it out, but maybe not.
On my Direct scan I show the 3rd and 4th gear lights lit up all the time. I unplugged the wire connector at the trans and grounded both wires out and that makes the lights go away. So, I have the pan off right now and replaced the pressure sensor in the center front of the valve body and that didn't change a thing. I can disconnect the wire from the sensor and ground it and the light goes out. Same way with the sensor on the side of the valve body. I can disconnect the wire and ground it and the light goes away. So, what kind of problem do I have? I figured a new sensor would fix the problem, but it doesn't seem to matter. I didn't replace the sensor on the side of the vb. The one in the front has a brown wire going to it and the one on the side has an orange wire going to it. I'm lost here.
