3rd brake light inop on my 86 GN
extranjeo
Is there anything I should head right to or just start chasing wires? Fuses are all good, no power to the harness connector in the trunk. All other lights are good to go.
i believe it has it's own wire that comes off the light switch on the brake pedal.. look there.
Check the connector by the fuse block. The harness runs from there under the door sill to the trunk.
BINGO!! The light blue wire from the 3rd brake light turns into a blue wire with a black stripe that goes to the brake light swich at the pedal. It appears that once I jiggled it, it reunited contact and now she works. I will purchase a new brake switch just to be sure. Thanks to all!
