There is a good chance your car came with the TH200C. This was looked down on by most people because it was believed to be a weak trans. We now know it was the heart of the trans used in the turbo cars. Many of the same parts used to improve the four speed will go into the three speed. The 200 model trans has a lower first gear, 2.74 than the 350 model with a 2.52.
You could also looking at adding some stall speed to the converter in the trans. If it is the 200 model, it will use the same converter as the four speed 200R4. There are many out there would allow you some additional RPM for starting out, but allow you to keep your rear gears for the economy when the converter locks up.
