Just curious, are you gonna countersink the head bolt holes in the block similar to the 86-87 109 block? If so, you could probably use the same studs as an 86-87.
If you countersink them how many threads are left? With the already thin decks I'd be worried about not having enough threads left to garentee clamping load.
