Have a 4.1 build in the works (although not sure when it will all come together
). This is the "later" version of the 4.1 which I pulled from a '84 Riv. I have a good set of used .020 forged pistons
, turbo crank checked out great and will stay std/std, 2dot rods, yada, yada.
Question now is what compression ratio to shoot for? With my current combo I went with thicker gaskets (GM 87s on the undecked 84 block: about .060 thick compressed compared to original steelshim @.017 or .019
). When Im on it and running a ton of boost its a bat out of hell but all other times a bit sluggish before it kicks in for me to really enjoy it.
My machinist seems to think we should deck the block (which Im not opposed to because after all 86/87 blocks are decked and used thicker gaskets). However he also thinks I should go with a 10:1 compression ratio which sounds a bit high to me. I know I would like to up the ratio from what I have been dealing with [heck if for nothing else to get better gas mileage
] but need opinions on what to shoot for. I guess cometics would be in order, although I have always heard good things about felpro 1000s which I think are about .035 thick compressed right? Any suggestions would be appreciated. I have never blown a head gasket (knock on wood) and have beat the heck out of my motors so I want to plan this right and not start going the other direction because all of a sudden I cant run much boost without BOOM!
