Good decision! I run N/A with nitrous, and the 4.1 with a 3.625 stroke has so much more torque than a 3.8, there is no comparison. Be sure you countersink or recess the head bolt threads in the block. It will at least need billet caps on the center mains. I like the RJC girdle myself. It's a pain to have it machined and to assemble it, but I think it holds the bottom end together better than just caps. Just my opinion for my setup. There is a car in my area with a 109 block with a girdle, and it regularly runs high 9's with a stock crank and a girdle, and lots of boost on E85. That helped me decide on the girdle. A steel crank and center caps seems to hold up on the turbo cars with good tuning as well. You will also find that the ring packages that are available will determine the bore size. Usually standard bore is not a problem and .030-.040 is also available from JE in file fit.
