4 wire plug o-ring
esinger
Stroker Hot Air
Does anyone know where I can get a new o-ring for the 4 wire plug/harness the goes through a hole on the drivers side of the transmission? I'm leaking transmission fluild through the plug hole.
I took the plug out and carried it to several auto parts stores and only find two sizes that come close.
One o-ring fit really well, but wasn't thick enough to seal well (OD measurement is 7/8ths). I test fitted it and it slide right in, but the plug was loose in the transmission case.
The other o-ring was thick enough, but was very loose fitting (OD Measurement is 1"). I could freely spin the o-ring around the plug and when I test fitted the plug it into the transmission case, it prevented the plug from locking into place.
