I am frshing a trans i got from a friend, It has a dual fed direct setup in it, But hte reverse feed is not blocked, It has a modified trans brake valve body with an aluminum plate, Could it be blocked in the plate? That idea just popped in my head so ill check.
Also i read about resticting the convertor feed in the pump for thrust reasons. Is this a good idea?
