400 turbo ??
JUSTAV6
Getting High On PSI
Is there any mod that I can do to my 400 turbo trans ,, When you hold it in first and try to hold it is shifts on its own ,, Just as its makeing power it shifts,,, Can I fix this with out putting a man vavle body in it,,,????? It in my truck not the buick,,,,
Thanks for any and all the help,,,,
Seneca Lafler
Transgo kit it. That will work.
If not in your game plan, then heres what you do. Cut 1-2 shift valve land off. Then plug exhaust hole in VB with plug. DONE!
you can also take weight off the governor or put weights on it from a 700r4 4wd with the inner triangle style weights if you dont want to drop the valvebody or pan.this will give you another 1500 plus rpm in manual low.
if three rivers is anywhere near
kalamazoo, i can bring the valve{s} {depending on the big or little version} and the plug for n/c. Let me know, i'll be in the area saturday. :D
Re: if three rivers is anywhere near
Hey Mike,,,
I'm about 30mins from K-zoo,,, And What would it cost me for the parts??
Thanks For the Reply Mike,,
Thanks Again,,
Seneca Lafler,,
Parts are N/C. I have plenty of both size
valves {depends on the valve body 1-2 shift valve bore size}. I'll bring the vb gaskets, valves,and plug. If you have the valve body out we can install the parts while i'm in town or i can bring the instructions. Email me at mridings@ford.com
Re: Parts are N/C. I have plenty of both size
Sent ya mail,,
Thanks Again Mike,,
Seneca Lafler,,
