My car came with the AVC dash from the previous owner and it has served me well. It has about 150k miles on it. That VDO speedometer is cable driven and you need a VSS from Jags that run.com. Costs $85. Get one soon as they are in short supply. There is no oil pressure dummy light so I would run the dummy light wire to the security bulb if you don't have a factor security system. The speedometer bulb and tach bulb is kind of dark so I would get an led replacement bulb if they make them.
I will take the Bailey 2 step if you still have it. do you have a switch for pedal to go with it? thanks
FYI........I've got the installation instructions in pdf format for the AVC "GNX style dash / VDO gauge set up" if anyone would like.
Just LMK.
I'm interested in (p) is it complete and ready to install. Is there any tunes on it all ready
